Important Does not display correctly installed translation
15 years 4 months ago - 15 years 4 months ago #83414 by silwius
I've created your own translation into Slovak Kunena 1.6.2. Sites begin to form in Joomla 1.6. I installed Kunena. I installed my translation and I found errors. Language files have been translated throughout the set and the administration. However, instead of translation (for example, Remember me), I print the code (ie: COM_KUNENA_LOGIN_REMEMBER_ME). I checked the translation, everything is correct, as it should be. This error makes me on several items, eg. and "Mark Topics Read" print me "COM_KUNENA_BUTTON_MARKFORUMREAD. This error does only in Joomla 1.6. In Joomla 1.5.2x everything works correctly, showing you the full translation. I do not know what to do with it. I want to use the forum to Joomla 1.6, but can not because of these errors. Enclosed is my translation.
Please help and soon. Thank you.
File Attachment:
File Name: Sk_languag....6.2.zip
File Size:47.57 KB
Last edit: 15 years 4 months ago by silwius.
15 years 4 months ago #83445 by xillibit
Are-you sure that you put translation files in the right place ?
15 years 4 months ago #83509 by silwius
Yes, I am 100% sure
