Question How To? Set up / find moderate forum. Add text to index tabs, ie rules, help, etc?
15 years 8 months ago #82336 by philbailey
Newbbie here. Can seem to be able to get a handle on moderation. Cant find moderation tools. Dont know if moderation set up correctly. Basically, not able to moderate at all.
Cant find out how to put some actual useful text in the index tabs like rules, help, etc.
I've searched forum, documentation, and google. If I missed something please point me in the right direction.
PDB
15 years 8 months ago #82354 by philbailey
Thanks,
Just after posting, in another frustrated try...right there in the documentation is how to set up Rules and Help. I dont know I missed it the other 50 times I searched;)
One further question. In Category Manager/Moderation no one show shows up in the moderator list unless they are assigned moderator in the Rank Title of User Manager. And the Category Manager/Moderation has this:"Please note: after setting moderation to Yes, you must save the forum configuration first before you will be able to use the new button to add moderators." I cant find a new button in this tab no matter what order I use of saving and assigning titles.
Thanks for your help.
15 years 8 months ago - 15 years 8 months ago #82359 by sozzled
philbailey wrote: In Category Manager/Moderation ...
Let's stop here for a moment.
The page Component » Kunena Forum » Category Manager » Moderation is where you define whether a category will be moderated or not. If you do not define the category to be a moderated category then you cannot assign category moderators to that category. But global moderators can still moderate an "unmoderated" category; global moderators have moderator privileges on any category that they have access to.
philbailey wrote: I cant find a new button in this tab no matter what order I use of saving and assigning titles.
I'm sorry, I don't understand what you mean. Saving and assigning titles? What are we discussing?
You do not use the rank title of "moderator" to assign moderators. It's all explained in grisly detail in How to assign a moderator in K 1.6
15 years 8 months ago #83640 by jdenard
Hi I can't add a moderator to a category. there is no button to add a moderaotr
see attached screenshot
15 years 7 months ago - 15 years 7 months ago #84641 by nur_afini
Hi Jdenard
I think the reason you cannot find the button to add moderator is because you haven't defined the user as a Moderator in User Administration whereby in your case I think the menu is called User Manager menu.
Below is the steps:-
1. Go to Kunena Control Panel
2. Go to User Administration / User Manager
3. Click on the user that you want to assign as a Moderator
4. On the Moderation section, select Yes and choose which Forum the person will be the moderator.
Notes: A person can be a moderator for more than one forum category, just press Shift button if you want to select more than one forum category...
Hope this helps ;)
Last edit: 15 years 7 months ago by nur_afini.
Time to create page: 0.260 seconds
