Question Joomla 1.6/ Kunena 1.6 Problem Category Parent: Not Showing
15 years 10 months ago - 15 years 10 months ago #82244 by shanekiller
Umm well this is a tricky one to explain and I can really take a screen shot because I'm at school on the schools computer but anyways I go to add a new category and I can a top level category for example
.Gaming2Gamers
...Announcements
...Help
When I go to add a new one and I go to select witch category I want to place it under only Gaming2Gamers is showing
.Gaming2Gamers (Shows Fine)
...Announcement (Not showing but shows a blank area where is should be)
...Help (Same thing with announcements)
I've tried to look it up but I really couldn't figure out what to look up I looked up parent missing etc and nothing shows up.
UPDATE::
Also when I try to reorder the category's using the arrows it just shows links on the top of the page (Components, Extensions, etc) and doesnt load anything else but when I use the numbers then save it. it works fine)
Thanks, Shane M. Kelley
Last edit: 15 years 10 months ago by shanekiller.
Time to create page: 0.094 seconds
