Question [SOLVED]Redirection issue with SEF and Joomfish
I've runing a Joomla! 1.5.2 with System-SEF Plugin activated. The Site uses Joomfish for translation.
Now if I want to enter a board in the forum i get no output but an error message that there is an redirection issue.
I tryed to disable SEF in the Forum Konfiguration - same problem.
When I disable SEF URLs its running fine ... :blink:
Any help is appreciated! Thx a lot!
Frank
EDIT:
I added an htaccess user for debugging / help.
www.inpro-childcare.de
user: gast pw: gast
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 50M | Max file upload: 8M
Joomla default template details : INPRO_TPL | author: Frank Romeike | version: 1.2.0 | creationdate: 12/26/07
board_title Forum EU Projekt board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 0 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template inpro_forum_tpl showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 0 askemail 1 showemail 0 showuserstats 0 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 0 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 0 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login none integration_avatar none integration_profile kunena integration_private none integration_activity none boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 0 showthankyou 0 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0
IG@ReK: What, specifically, is the problem that you are having? Do you have Joomfish? Are you running K 1.6.1. How you you know that you have the same problem ... ?
To both WebbR and IG@ReK: What is the exact text of the error message that you receive? Have you searched this forum for the exact text of the error message that you are getting?
user: gast pw: gast
My Kunena is a fresh install of 1.6.1 -
I set up the Joomfish Router like using different domains for each language.
English-->.net German -->.de French-->.eu
May this cause the problem?
The Errormessage is in German... here it is:
Fehler: Umleitungsfehler
Die aufgerufene Website leitet die Anfrage so um, dass sie nie beendet werden kann.
* Dieses Problem kann manchmal auftreten, wenn Cookies deaktiviert oder abgelehnt
werden.
Here is the Kunena configuration:
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 50M | Max file upload: 8M
ThX for the support!!! And ThX to the Kunena-Team for the great work!
