Question BBcode Problem..
15 years 11 months ago - 15 years 11 months ago #72266 by Baralak
BBcode Problem.. was created by Baralak
Greetings, I just made the plunge and converted my SMF 1.X forum to Kunena 1.5 then upgraded to 1.6. I'm of course using Joomla 1.5. My problem is in the signature portion. The users of the website use a stats bar that is generated by Geocaching.com. The bbcode that we used on the old site is as below I removed the [ 's so that it would print
url=http://www.geocaching.com/profile/?guid=9399320a-2378-45d7-b614-2bf6195e6ece] img] img.geocaching.com/stats/img.aspx?txt=Le...f6195e6ece&bg=1[/img [/url
What we get is just the text in the image portion.. as you can see by visiting my site and my profile..
www.nelageo.net/testing/index.php?option...nc=profile&Itemid=60
Is there something that I'm doing wrong?
Baralak!
Last edit: 15 years 11 months ago by Baralak.
15 years 11 months ago #72282 by xillibit
Replied by xillibit on topic Re: BBcode Problem..
You can't put in bbcode images generated dynamically, because could be in some cases a security issue.
15 years 11 months ago #72312 by Baralak
Replied by Baralak on topic Re: BBcode Problem..
Hum... Do you know of any way then that this can happen? This is a huge part of what we do.. Any work arounds?
15 years 11 months ago #72313 by sozzled
Replied by sozzled on topic Re: BBcode Problem..
There are no workarounds that I'm aware of, sorry.
15 years 11 months ago #72316 by Baralak
Well.. do you happen to have any suggestions? Any thing else I can do.. I hate to have to switch forums again. I must admit that I didn't beta test the stat bar portion, but that is something that we will have to have.
15 years 11 months ago - 15 years 11 months ago #72317 by sozzled
What, exactly, do you want to do that using on-the-fly-generated images will "achieve"? Would any other features of Kunena serve a similar purpose?
Last edit: 15 years 11 months ago by sozzled.
