Question Problems Viewing the Replies or Topics Under Categories
16 years 1 week ago - 16 years 1 week ago #70148 by masky
I am hoping someone could help me out; I had installed k1.6.0 and added all the categories etc. But when there were topics or replies added there was no way of viewing them when you clicked into the categories field. They only showed up under the last post box, which is on the very right of the forum or under the recent topics tab. So I decided to reinstall and upgrade to k.1.6.1thinking there was a bug issue or I mis-configured it. I still got the same issue with a fresh install! I am in desperate in need of help.
Please help! Waiting for your replies
Thank you,
THIS IS THE CONFIGURATION SETTINGS DISPLAYED ON BACKEND
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : gk_gamebox | author: Robert Gavick - GavickPro | version: 1.0.12 | creationdate: 25/06/2010
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
Last edit: 16 years 1 week ago by masky.
16 years 1 week ago - 16 years 1 week ago #70164 by masky
I just fixed the problem, after hours of trying to figure out what was wrong... I have attached an image to help others, if they come accross the same problem.
:woohoo:
16 years 1 week ago #70172 by haithun
Thats not true. Please dont write solutions for problems you dont understand cause they are just wrong.
Can you give us the URLs that are created when having SEO turned on?
16 years 1 week ago - 16 years 1 week ago #70180 by sozzled
masky: If you try to enable Joomla SEO and you do not have a .htaccess file, then your forum (and a lot of your website, too) will not work.
Your configuration shows that you do not have a .htaccess file. You have not understood how to properly setup Joomla SEO. Please read this important article: Search Engine Opimization (SEO) .
Last edit: 16 years 1 week ago by sozzled.
The following user(s) said Thank You: masky
