- Thank you received: 22
Question Ban system removing ip addresses when messages deleted
- woonydanny
- Elite Member
so i went into the backend trash manager and deleted all their posts but now when i go back into the kunena user manager it does not show any IP addresses associated with this user. are they still banned? i would like the ip system to still retain the ip addresses that have been used even if the messages get deleted.
thanks
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
There are many possible reasons why, if you say you click the "delete all posts" checkbox, the messages were not deleted. I don't know because I wasn't looking over your shoulder when you did it.
When you delete messages they go to the trash and they are still visible (to system moderators/admins) until you empty the trash. When you empty the trash, the records are expunged from the messages table(s). There is a separate table that manages user bans. Therefore when you ban someone, the record of that ban is held in a different location to where their messages were stored.
The feature that shows "IP addresses used by this user" draws that information from the messages table. Therefore, if the messages are permanently deleted then so, too, is the information that you're looking at with that feature. It's a tough ask, how to record all IP addresses used whenever a user account does something on your website. I don't think I've seen a satisfactory solution to that problem anywhere.
All IP usage is recorded in your site log. The next trick is to associate an IP address with a registered user account. The last step in the process is to preserve all that information ... forever!
K 1.6.x does not have a ban-by-IP address function at the present time.
- woonydanny
- Elite Member
sozzled wrote: I posted an item in the forum a while ago about deleting all messages from a user when you ban them: see Easily delete multiple posts from one user?
yes, i understand all if this, however it does seem a loophole in the ban system that you cannot ban a member from their ip and also delete their posts. But more importantly I cannot see all the ip addresses used by the user to ban them once the posts are deleted. maybe there should be a way that these ips are left in the system once the messages are deleted so there is an ip history of this banned user, as these types of users are the ones you want the ip info for!!
To be able to delete all messages, yet keep a hidden copy around.
