Question Kunena RTL CSS for K1.6 Final
16 years 1 month ago - 16 years 1 month ago #65747 by Masoud
You will find the RTL version of Kunena 1.6 Final CSS Final. It's perfect for Persian and Arabic and the other RTL languages, I've attached two different css file for Arabic and Persian, the only different between these two files is font-family the other modification are the same.
Live website with new css files:
www.cyberg.ir/index.php?option=com_kunen...t&catid=0&Itemid=119
Last edit: 16 years 1 month ago by Masoud.
The following user(s) said Thank You: fxstein, zomblaa, Greight, bid, kobiavr, hamidy
16 years 1 month ago - 16 years 1 month ago #65836 by sozzled
Thanks, Masoud. Would you like to add this to the Kunena Extensions Directory ? I think it would be better placed there and it would be easier for other users to find it, too.
Last edit: 16 years 1 month ago by sozzled.
The following user(s) said Thank You: Masoud
16 years 1 month ago #65996 by Masoud
sozzled wrote: Thanks, Masoud. Would you like to add this to the Kunena Extensions Directory ? I think it would be better placed there and it would be easier for other users to find it, too.
I can find some problem in css files after fixing them, I'll ask you for that.
16 years 1 month ago #66269 by zomblaa
it's what I need :)
I will try it
Thank you very much
16 years 3 weeks ago #68082 by Greight
Thank you Masoud. It was really great. Just one problem. Everything gets rtl except for main category names on main page. I used Persian version BTW. Can you fix it, please?
16 years 1 week ago - 16 years 1 week ago #70544 by kobiavr
thank you Masoud
I think the RTL should be part of the component
What happens when we working with joomfish?
When I work with design templates I'm working with this code
<?php if($this->direction == 'rtl') : ?><link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/template_rtl.css" type="text/css" /><?php endif; ?>
We need to see how developers can add this to the component
Then you must create another CSS file in the library
I want to know what you think and what the developer's opinion
Sorry if my English is not clear
kobi
Last edit: 16 years 1 week ago by kobiavr.
