Question Another problem with setting up the Kunena menu
15 years 11 months ago #64964 by duker733
I have a question about the menu as well. On my site my top menu which is displayed by my template highlights the menu item you are on when you click on it. But when I am on the forum menu item (which is the kunena menu) it is not highlighted? Is there any way to fix this?
My site is www.okanagansportbikes.com
15 years 11 months ago - 15 years 11 months ago #65688 by duker733
I hope I explained this problem enough to understand. Kind of hard to explain? Can anyone offer any suggestions why this may be?
It's the same as this site. When you are viewing the forums the "forums" menu item is highlighted in blue in between Home and Team. All the menu items on my site are highlighted when selected except for the Forums menu item, which is the the Kunena default root.
Last edit: 15 years 11 months ago by duker733.
15 years 11 months ago #65696 by sozzled
Your site is not the same as this site. You are using the RocketTheme Versatility J 1.5 template. This website is using something different. You are using a drop-down menu at the top; this site doesn't.
In all other respects, I don't see any problems with the way that Kunena is running on your website. Other than these things, I don't know what more I can say. Have you asked RocketTheme ?
15 years 11 months ago #65704 by fxstein
I believe this is due to how you setup your main menu.
Is it an alias to Kunena_Menu or a simple entry pointing to the Kunena component?
If you use the alias, the menu highlighting should be automatic.
Time to create page: 0.233 seconds
