Question Forum tools at topic-list gives a 0 return
16 years 1 month ago - 16 years 1 month ago #64877 by Balázs
Hi!
In the topic-list Forum tools don't work (move, delete), and it gives a 0 return. If i go inside a single topic, they work.
Any idea?
Best regards.
Balázs
Last edit: 16 years 1 month ago by Balázs.
16 years 1 month ago #64900 by xillibit
Can-you put here your kunena configuration settings ?
Do you have a test account for your site (use
to let only moderators to see the datas) ?
16 years 1 month ago - 16 years 1 month ago #64904 by Balázs
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 100M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.7) | UddeIm: Disabled or not installed
16 years 1 month ago - 16 years 1 month ago #64937 by Balázs
I tested a little with different Joomla templates and it seems it isn't compatible with RockeTheme templates using Gantry framework. Using templates like that makes it give a 0.
16 years 1 month ago - 16 years 1 month ago #64970 by sozzled
Under these circumstances, I would suggest that you direct your enquiries to the good folks at Rockettheme . Please let us know how you get on. :)
I have a feeling that this may have something to do with "build title spans" - a feature of some (?) Rockettheme templates.
Last edit: 16 years 1 month ago by sozzled.
16 years 4 weeks ago #67056 by kat06
hi all,
here is the link to the thread at the rockettheme forum, at the moment this seems to have been caused by some shoutbox component. we may be able to mark this solved.
www.rockettheme.com/forum/index.php?f=33...12639&rb_v=viewtopic
greetings,
kat :)
rockettheme
Time to create page: 0.154 seconds
