Question Mootools and missing BB code buttons question.
16 years 1 month ago #64855 by rockinon
I have a template that uses it's own mootools 1.1 version for a top menu. It will still work with version 1.2.4. Would it be possible to point the template to the newer version of mootools and get my Kenuna functions to also work at the same time? If so, where is the Mootools 1.2.4 library when you enable the "System - Mootools Upgrade" in Joomla so I can direct it to the correct location?
16 years 1 month ago #64860 by fxstein
If that template works with mootools 1.2.4 you should only have to enable the the MTUpgrade system plugin.
You can also see the download path if you go to the forum page and use Firebug or Chrome developer tools and look at all the included scripts.
Should be in /plugins/system/mtupgrade/mootools.js
Hoep this helps!
