Important Wrong options for moderator in front-end
15 years 7 months ago #63791 by marco168
I have ticked "NO" to the option "Allow to moderator to view and restore deleted messages" in back-end. But now moderator (not administrator) also can choose "Restore" and "Preminantly delete post" at the front end.
Is it the bug of Kunena? Could anyone help disable these two option in front-end?
Thanks a lot;)
15 years 7 months ago #63804 by Matias
I cannot reproduce your issue.
Do you have custom template? Have you modified any files by hand?
15 years 7 months ago #63947 by marco168
The problem appears when I choose the default template of Kunena.
I have not changed the system file of Kunena.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Kunena version detailled: Installed version: 1.6.0-RC3 | Build: 3539 | Version name: Jadili | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
15 years 7 months ago #64018 by Matias
It could be fixed for Kunena 1.6.0, but I don't remember seeing any bug/change like this. Check if you have translations in wrong order (or use English to verify it).
