Question Is it possible to push advanced search parameters through a module
15 years 8 months ago #58919
by xpozay
I would like to set up a module that allows my members to search the forum without using the search box (advanced search box). The module would pre-configure a number of the search parameters allowing the users to configure a few others. The result would push the search request to the Kunena search "API" displaying the results as they currently do.
Is this possible? I guess in developer talk can I post the search parameters to the search function?
Thanks in advance
Chris
Thanks in advance
Chris
15 years 8 months ago #58923
by Matias
Replied by Matias on topic Re: Is it possible to push advanced search parameters through a module
Its possible, but not planned at this stage.
- woonydanny
- Elite Member
- Thank you received: 22
15 years 8 months ago #59033
by woonydanny
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
Replied by woonydanny on topic Re: Is it possible to push advanced search parameters through a module
good idea for another module
15 years 8 months ago #59274
by xpozay
Replied by xpozay on topic Re: Is it possible to push advanced search parameters through a module
Thanks. Given it is not planned, I may embark upon this myself. Do I just use the http post command or is there an API I can call?
15 years 8 months ago #59275
by Cerberus
Replied by Cerberus on topic Re: Is it possible to push advanced search parameters through a module
administration/component/com_kunena/
kunena api files are in there
15 years 8 months ago #59390
by Matias
No, search is not in there. It's older code and in frontend.. com_kunena/lib/kunena.search.class.php
Time to create page: 0.225 seconds
