Question Is it possible to push advanced search parameters through a module
15 years 8 months ago #58919 by xpozay
I would like to set up a module that allows my members to search the forum without using the search box (advanced search box). The module would pre-configure a number of the search parameters allowing the users to configure a few others. The result would push the search request to the Kunena search "API" displaying the results as they currently do.
Is this possible? I guess in developer talk can I post the search parameters to the search function?
Thanks in advance
Chris
15 years 8 months ago #58923 by Matias
Its possible, but not planned at this stage.
15 years 8 months ago #59033 by woonydanny
good idea for another module :)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
15 years 8 months ago #59274 by xpozay
Thanks. Given it is not planned, I may embark upon this myself. Do I just use the http post command or is there an API I can call?
15 years 8 months ago #59275 by Cerberus
administration/component/com_kunena/
kunena api files are in there :)
15 years 8 months ago #59390 by Matias
No, search is not in there. It's older code and in frontend.. com_kunena/lib/kunena.search.class.php
Time to create page: 0.337 seconds
