Question Some problems with Opera and Firefox
16 years 3 months ago #56267 by vol001
Hallo!
I have some problems with changing user info in profile when I use Opera and Firefox.
Also, I cannot add smiles in messages when I use "smile buttons".
In IE8 on the contrary everything is OK!
Don't you know what I have to do to solve this?
Please, I need a little advice from you!
Thanks.
The following user(s) said Thank You: dok69
The topic has been locked.
16 years 3 months ago #56269 by vol001
I use kunena 1.6
16 years 3 months ago #56283 by xillibit
Can-you please report configuration details : www.kunena.com/forum/156-k-16-test-repor...tion-for-test-report
The following user(s) said Thank You: vol001
16 years 3 months ago #56288 by vol001
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
16 years 3 months ago #56321 by Matias
Can you tell us what you try to do and what happens in the profile?
Smileys could have some kind of JavaScript conflict.. Hmm.
16 years 3 months ago - 16 years 3 months ago #56337 by vol001
You may try to do something yourself with the profile.
Just register on build-fix.ru. Enter the site with Opera or FireFox. Open "Мой профиль" (Profile). Select "Изменить" (Edit) to edit info. And you will find no "alive" function to change! No ONE!
Hm?..
Last edit: 16 years 3 months ago by vol001.
