Idea Same URLs after upgrading from K 1.5 to K 1.6?
15 years 9 months ago - 15 years 9 months ago #56008 by jeff_j_dunlap
Will a forum that is upgraded from K 1.5 to K 1.6 keep the same URLs for menu items as well as forum messages?
Joomla SEO Settings
- Search Engine Friendly URLs: Yes
- Apache Mod Rewrite: Yes
- Add Suffix to URLs: Yes
Thank you
P.S. The following is a bit off topic to my question but gives the reason for my concern. I have a different Joomla site that was using SmartSEF but due to some problems, I migrated to Joomla's native SEF. Before doing this, I carefully preplanned the transition, making a list of all the URLs with decent pagerank and after uninstalling SmartSEF and enabling Joomla's SEF, I 301 redirected my old URLs to the new URLs and even so, lost all of my pagerank.
Here is an example of a page that had pagerank and now the page has no pagerank (even though you can see the 301 redirect in action, which google suggests you do when changing URLs):
Old SmartSEF URL:
www.postales-apasionadas.com/poemas/novios.html
Flawlessly 301 redirects to New Joomla URL:
www.postales-apasionadas.com/poemas-de-amor-en-espanol.html
This was update was done I believe, about 6 months ago.
Last edit: 15 years 9 months ago by jeff_j_dunlap. Reason: clearification
15 years 9 months ago #56167 by Matias
Kunena 1.6 will use custom menu aliases, but you can rename them to be the same (if they are not). But even if you end up using the new names, Kuenna will still accept most of the old URLs. I've never actually tested this, but if should work.
Please note that we are using Joomla menus to show our own menu. So to avoid issues, I would first play with K1.6 in test environment -- copy your production environment and look how it works for you and if you need some help from us.
