Question Kunena 1.6 ITALIAN TRANSLATION
16 years 2 months ago #52095 by MAW_Trok
At moment I am at 80% of translating the Fronted. In a 2-3 days I should finish and I'll post the first file.... another week and will come also the Backend!
PEr la traduzione di kunena 1.6 in italiano manca poco. E' una versione beta e potrebbe esserci qualche errore, per questo consiglio di controllarla una volta istallata.
16 years 2 months ago #52158 by xillibit
it's nice to have too an italian translation for kunena 1.6
I hope that your translation is based on SVN, because the alpha2 is a bit outdated.
16 years 2 months ago - 16 years 2 months ago #52164 by MAW_Trok
ops... my translation is on alpha2... but don't worry I can do again..... sorry but alpha2 don't was the latest version? you have another latest version?
Last edit: 16 years 2 months ago by MAW_Trok.
16 years 2 months ago - 16 years 2 months ago #52175 by xillibit
Alpha2 is the version publicly available, but in the SVN there are changes every day.
I advise you to get these files to don't re-do multiples times the work :
Read the doc for more info on k1.6 translation : docs.kunena.com/index.php/What_is_the_la...e_file_in_kunena_1.6
Last edit: 16 years 2 months ago by xillibit.
16 years 2 months ago #52296 by MAW_Trok
ok perfect... after this files..... do you think that kunena will be changed again or I can translate without problems :-D
Time to create page: 0.290 seconds
