Idea Kunena 1.6 known issues
- mootools migration plugin causing conflict: In preparation of Kunena for Joomla 1.6 we are using the latest mootools 1.2 plugin for Joomla 1.5 - a conflict is causing a few of our functions to fail on java script errors: e.g. form validation and polls - as soon as a bugfix has been provided by the Joomla core dev team, we will update Kunena.com and release Kunena 1.6.0 Beta
- woonydanny
- Elite Member
- Thank you received: 22
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
Randal wrote: Beta will be ready to use on production site? Or RC?
NO betas are not to be installed on production sites, release candidates (RC) can be but it is at the risk of the sites admin as it will not be supported until stable release.
But like peetree21 said, I would start using it only in the live site if I was skilled enough to do things manually -- with or without help of devs. Most of our current live site testers have direct contact to our developers by Skype chats.
Anyway, it's up to you if you want to give K1.6 alpha/beta a try. If it works in the test site without issues, it's highly likely that it does the same in your production site.
