Merged Forum transfer (not a merge): from J! 1.5 to J! 2.5 - SP Upgrade
14 years 3 months ago #125918 by Tomservo
Very interested in what changes are on the way for this topic as I'm looking to do the same upgrade in the coming weeks and need a well defined "plan of attack". If jupgrade migrates Kunena then I'm obviously looking at that option first. Just looks like it will take me a weekend set aside for the aftermath of the rest of the migration process. :)
14 years 2 months ago #128779 by kross76
I'm trying to follow these instructions with K1.7.2 -- as a test conversion. I keep getting an error message "500 - An error has occurred. Another menu item has the same alias in Root. Root is the top level parent" (see attached). I have made sure (I think) I've deleted any Kunena menu items. I've tried clean install, etc. Any sense for what this error really is?
14 years 2 months ago - 14 years 2 months ago #128784 by sozzled
*** This is off-topic ***
When you receive the error message "500 - An error has occurred. Another menu item has the same alias in Root. Root is the top level parent" it means exactly that. Another menu item exists with an alias name that is identical to the alias name of one of the Kunena menu items. Change the existing one to use a different alias name, then install the Kunena menu, then change things around again.
Simple if you understand how the Joomla menu system works. The problem is, most people don't understand how the Joomla menu system works. See How do I restore my Kunena menu?
This problem has nothing to do with using SP Upgrade.
Last edit: 14 years 2 months ago by sozzled.
Time to create page: 0.220 seconds
