Question Problem with Kunena Session
14 years 7 months ago #121648 by Natarandon
I have the following problem.
Some of the categories are only visible to members of a certain joomla usergroup. Now if a user becomes member of that group he should be able to view that category.
But in my case nothing happens. I changed the session lifetime to just 5 seconds but still the session and thus the allowed field is not changing. Even loggin out, waiting and then logging in again does not help in any way.
What can be the problem?
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
14 years 7 months ago - 14 years 7 months ago #121671 by sozzled
G'day, Natarandon, and welcome to Kunena.
Set the Kunena session lifetime to be the same as the Joomla session lifetime. 5 seconds is too short.
If you change a user from one user group to another one, use the Synchronize Users feature to clear the Kunena session cache so that these users will be able to view different categories that you have protected/restricted with Joomla's security features. Alternatively, have your users logout and then login again after you change the group they are assigned to. I think this will resolve your problem.
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago #121710 by Natarandon
I just thought that the shorter lifetime would fix the problem ;) I'll change it back.
Logging out and back in doesn't solve the problem though. Still the Kunena Session is not updated in the database. And it would be weird if I had to sync the users in the database whenever there is a change in some userrights.
14 years 7 months ago #122125 by Natarandon
Nobody else has any idea?
14 years 7 months ago - 14 years 7 months ago #122149 by sozzled
If you change a user from one user group to another one while they are logged-in then you need to use the Synchronize Users feature to clear the Kunena session cache so that these users will be able to view different categories that you have protected/restricted with Joomla's security features. Alternatively, ask your users to logout and then login again after you change the group they are assigned to.
What are your settings for
  • Global Configuration » Server » Cache Settings » Cache
  • Global Configuration » Server » Session Settings » Session Lifetime
  • Forum Configuration » General » Basic Settings » Session Lifetime
Turn off server caching and make Global Configuration session lifefime (in minutes) the same as Kunena session lifetime (in seconds). If Kunena session lifetime is 1800 seconds, make Global sessions lifetime = 30 minutes. I am sure that, for a site with only three members, running the Synchronize Users feature is not going to be a major problem for you.
Also, read Search Engine Optimisation (SEO) in the Wiki.
I see that your site has 3 members in total. One of them is the site administrator (you) and the other two are test accounts. Are you really sure that you're logging out of these test accounts?
14 years 7 months ago #122181 by Natarandon
I'll try these settings again and hope for the best.
And the page has only these three users since it's a test page ;) The main page has a few users more. And using the Sync is not an option since the changes in the user group are done automatically by a component.
