Question A valid URL was not supplied. error
14 years 8 months ago #121028 by dcsvany
Not really sure if this is a Kunena issue ut it does only display after I load up and new topipc or reply to a new topic.
I get a error after replying or creating a new topic states "A valid URL was not supplied."
Maybe a joomla issue but I just do not know who to turn to right now.
Attached is the report.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : mv2 | author: Joe Bower | version: 1.3 | creationdate: 2012-02-20
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.2 | Kunena Discuss 1.7.2
Modules: Kunena Latest 1.7.2 | Kunena Stats 1.7.2 | Kunena Login 1.7.2 | Kunena Search 1.7.2
14 years 8 months ago #121057 by sozzled
The problem is caused by the Kunena template that you are using. Please contact the author of that template for advice. Alternatively, use the Blue Eagle template.
Please also read Search Engine Optimisation (SEO)
