Question Multi-language Help and Rules Pages
14 years 9 months ago #117766 by adop
I have a multi-language site for which I would like to have a help page in several languages.
Since in Forum configuration there is only place for 1 article ID I assume that some sort of text replacement must take place in that article.
I use NoNumber Sourcerer to include PHP code in the article. The result is that when I load the Help article through a menu item the PHP code is run regularly while when I check the outcome of the same code in the Forum Help Page the content is blank without any error. It would seem that the PHP code is stripped out completely.
how should I proceed to get different help pages in different languages?
Thanks,
adop
14 years 9 months ago #117771 by Jiminimonka
Or you could have the article that Rules points to have several sections with a link at the top to take the user to the correct language section.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago #117849 by adop
Technically possible but not clean. If I have different people managing different languages they would interfere.
14 years 6 months ago #123526 by fabrice4821
Have you find a right solution ?
14 years 6 months ago #123543 by LittleJohn
Old settings define old problems. Now that Joomla is much more flexible regarding languages, there could be better solutions.
Im thinking ... Would it solve the problem if you could select the article within the menu items for "rules" and "help" instead?
14 years 6 months ago #123553 by sozzled
Here's a totally wild suggestion - a lateral approach to the problem: write the rules and help in several sections, one for each language. Costs nothing but a little bit of time! ;)
