Question Problems with Date Format and "Unknow" Fields
14 years 10 months ago - 14 years 10 months ago #115484 by Orion_rx8
Hi again,
I have splitted my last topic in the right section.
I have this config on my site Rx8.it
Joomla 1.5.25
Jomsocial 2.4.1
Kunena 1.7.1
Now, I have 1 big problem.
All the dates are now visible. Posted on, last visit date etc... are "Sconosciuto", "Unknow" in english. When I look in the admin area, on the field Time Format I see
Now visible
Unknow
Unknow
Unknow
In the database, when I select the second, I can see "AGO" data.
Tried to change the template with the standard, tried to reinstall and tried to change language but nothing solved.
Anybody can tell me where is the file (or files) where the software kunena try to get the Date Format?
Thank you
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : rt_tachyon_j15 | author: RocketTheme, LLC | version: 1.5.9 | creationdate: December 12, 2011
Kunena default template details : Aqua Social | author: Tessak22 | version: 1.6.x | creationdate: 2010-04-9
Third-party components: Jomsocial 2.4.1
Last edit: 14 years 10 months ago by Orion_rx8.
14 years 10 months ago #115513 by sozzled
These look to be problems caused by the Aqua Social template. Please contact the author of that template to resolve your problems or use the Blue Eagle template designed for K 1.7.1 instead.
