Question The breadcrumb is not working after selection forum link
14 years 9 months ago - 14 years 9 months ago #116907 by sozzled
The breadcrumbs are displayed or not displayed as function of the Kunena template you are using. If you are using the standard, unmodified Blue Eagle template then the breadcrumbs will be displayed. If you are using a different Kunena template then you should discuss your problem with the author of that template.
If you are using the standard, unmodified Blue Eagle template and you still are having problems, please post your configuration report and we will try to find out what is the cause of your problem. Thank you.
Last edit: 14 years 9 months ago by sozzled.
Time to create page: 0.086 seconds
