Question Kunena doesn't work with Easy Calc check Plus
14 years 10 months ago #113379 by DiploDicto
The famous plugin Easy Calc Check is not compatible with the Kunena register page. The captcha code is not visible but input is required, making it impossible to get past the register screen for new user.
Quick Fix, dont use captcha against bots on your register page.
14 years 10 months ago #113384 by xillibit
For your information, the register page is only generated by Joomla! itself.
14 years 10 months ago - 14 years 10 months ago #113408 by DiploDicto
Ok but the Register page is different now, since i use Kunena. There is a Mysiwig editor where user can put text and avatar upload.
Both is not required. Though a second page with such options would be neat. This could be configurable through the extensive Kunena configuration panel. I even suggest to implement an entire panel only for USER MEMBERSHIP (Register, form fields, profile fields.
Although user profile fields should be only visible in the user profile, once the user has entered input.
Please consider this to make Kunena the first choice BBS when it comes to Joomla!
If i can further assist you with my feedback and critical thinking skills, then say so. I liek to help you make your software better. It is lacking now.
Thank You for Consideration
Last edit: 14 years 10 months ago by DiploDicto.
