Question [Resolved] Problems arising from misuse of Create Menu
14 years 11 months ago - 14 years 11 months ago #112393 by [email protected]
I was trying to figure out how to work Kunena and I hit the "Create menu" button. Instead of taking me to a particular screen it just linked my forum to my site login page. I've been trying for hours and I can't figure out how to fix this. My site looks terrible. Please Help!
Last edit: 14 years 11 months ago by [email protected].
14 years 11 months ago - 14 years 11 months ago #112396 by sozzled
Replied by sozzled on topic Re: The Create Menu Button
You posted another question on this forum a while ago: Limiting Kunena . I responded but you did not reply to my response. Therefore, until I see a response to my previous unanswered questions I do not have any real advice to offer here.
[email protected] wrote: My site looks terrible ...
Perhaps, if you followed the advice given in the posting guidelines printed at the top of this page, we might be able to help better. :dry:
Last edit: 14 years 11 months ago by sozzled.
14 years 11 months ago #112480 by [email protected]
Sorry that I didn't reply to your post on my previous question, I solved my own problem and didn't realize that you responded. I had completely forgotten about it. As far as my accidental transgression of the forum rules, I apologize for that too. I was frustrated and wanted help and I didn't mean the offense that I have apparently caused. Our website is not online yet, so I don't think that the configuration code would help in this case. If you could give me a tip on how to reverse whatever happened when I hit the "Create menu" button I would be very grateful. Thank you again for your time.
14 years 11 months ago - 14 years 11 months ago #112481 by sozzled
No offence taken.
However, we cannot assist you with your problem if we do not have any idea of the environment you are running. It's not necessarily relevant (or important to us) if your forum is not fully operational at this time but it does help if it's accessible.
If you want to follow-up your original question and you seek our support, please read the posting guidelines printed at the top of this page and pay particular attention to What information should I include when I ask for help (including how to post my configuration report)?
If we have not heard from you within the next 24 hours we will consider this matter to be closed. Thanks.
14 years 11 months ago - 14 years 11 months ago #112510 by [email protected]
Here is my configuration report:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 50M | Max file upload: 20M
Joomla default template details : loginscreentemplate | author: | version: 1.0 | creationdate: 2011-11-16
Third-party components: Jomsocial 2.4.0
Last edit: 14 years 11 months ago by rich.
14 years 11 months ago #112512 by sozzled
Thank you for your configuration report. I strongly suggest that you immediately upgrade to K 1.7.1 and see if this fixed your current problems.
Further, you should also read Search Engine Optimisation (SEO) in the Wiki if you want to properly use SEF URLs and this may also have some bearing on your current difficulties.
I will look again after you have attended to these matters and you post an updated config. report. Thanks. :)
Time to create page: 0.172 seconds
