Question Change topic title after a post has been made
15 years 1 month ago #109342 by jheuser
Have a problem here and I have searched and not been able to find a way to fix it.
After a user posted they somehow changed the title of the topic. It changed from one sentence to about 5 sentences and looks bad.
How can I change the topic of a thread?
It can be seen here
jane.tv/forum/recent?view=latest&do=latest&func=latest
15 years 1 month ago #109366 by xillibit
You can edit the topic for now, in Kunena configuration panel you set a limit for topic subject
15 years 4 weeks ago - 15 years 4 weeks ago #109759 by jheuser
Will someone please help me with this. This is bad I can't figure out a way to fix it. I already tried limiting the topic subject length, but it did nothing. Look how bad this looks.
Last edit: 15 years 4 weeks ago by jheuser.
15 years 4 weeks ago #109777 by sozzled
I've seen this particular problem before (but I can't remember exactly what caused it). It was a long time ago when I saw various messages posted so I'm wondering if the issue affects an older, unsupported version of Kunena?
Can you please post your configuration report? This might help us to help you better. I'll keep digging around to see if I can find out where I saw this issue before. Changing the subject or limiting the subject length configuration setting won't cure the problem, by the way. If my memory serves me right, the problem is caused by some bug ... but in whose software is this bug? :S
15 years 4 weeks ago - 15 years 4 weeks ago #109778 by jheuser
Hi Sozzled. I attached the report. Thank you for helping me with this! It is a mess... This is a live website right now... Never a good thing when there is a problem.
Joomla default template details : rt_crystalline_j15 | author: RocketTheme, LLC | version: 1.5.10 | creationdate: July 15, 2011
Last edit: 15 years 4 weeks ago by sozzled. Reason: Reveal Kunena configuration report in message
15 years 4 weeks ago #109783 by sozzled
Hmmm ... a couple of recommendations for you. As I suspected, you're using an older version of Kunena (which isn't supported any more, by the way) and that may account for the problem. Your first plan of action should be to update to K 1.7.
I'm not sure about your Kunena menu set-up but if everything else is working fine then let's not mess around there. My only comment about the menu setup is that it looks a little "over-engineered" from my perspective.
Your configuration report looks like you've altered it somehow (e.g. you've removed the URL of your website). Please look at the FAQ "fact-sheet" What information should I include when I ask for help (including how to post my configuration report)? particularly in relation to the use of the
Time to create page: 0.156 seconds
