Question High CPU and memory used caused by Kunena Forum
15 years 1 month ago - 15 years 1 month ago #108075 by brenden
Hi all,
Long time user of Kunena and love it but a relative noob in terms of extreme techy detail. Recently over the last week we've had performance issues where our server CPU and memory use has spiked dramatically.
According to our host their server is OK and they pointed to Kunena forum causing the issue. They suggested something might be keeping data in cache.
Attached are screen shots of cpanel showing CPU and memory use.
Anyone seen / experienced this? Is there a way to disable cache for forum?
Any insight is greatly appreciated!
Last edit: 15 years 1 month ago by brenden.
15 years 1 month ago #108203 by xillibit
Can-you put here your Kunena report configuration settings ?
15 years 1 month ago - 15 years 1 month ago #108238 by PJFonseca
We at androidPT.com have the same problem.
The configs:
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0pt | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.4 | creationdate: 2011-05-07
Third-party components: UddeIm 2.0
Modules: Kunena Latest 1.0.47
Last edit: 15 years 1 month ago by PJFonseca.
15 years 1 month ago - 15 years 1 month ago #108250 by brenden
Report below - Apologies for not including originally:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 4M
Joomla default template details : stormlab | author: LineLab.org | version: 1.0.0 | creationdate: 29.4.2011
15 years 1 month ago #108305 by PJFonseca
Any thoughts on this?
15 years 1 month ago #108565 by Matias
Memory usage probably comes mostly from apache processes -- the more users you have, the more memory it takes. Disabling (or having at most 3 seconds) keepalive setting in Apache usually helps to keep memory usage lower.
CPU usage may be caused by anything and you really need to know which processes are taking the time.
Time to create page: 0.180 seconds
