Question Kunena menu problem
15 years 3 months ago #104693 by peterpj
Kunena menu problem was created by peterpj
I'm a newbie here having just downloaded and installed Kunena for the first time. First impressions - brilliant, and just what I was looking for BUT:
I tried to install the kunenamenu module on several pages. If I set module position to "left" I don't see anything, if I set it to "right", I see the menu title on the right side of the page but it has no list of menu items. I've had a good check around but I can't spot any reason for this. Thanks in advance for your help.
Peter
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 4M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
15 years 3 months ago #104695 by sozzled
Replied by sozzled on topic Re: Kunena menu problem
G'day, Peter, and welcome to Kunena.
I can't see the forum on your website: "Only community members can participate in forum threads. You must register or log in to contribute."
I suggest you read more about Joomla's Search Engine Optimisation (SEO)
I don't understand what you mean by assigning the kunenamenu module on the left or right. It should be assigned to the module position kunena_menu
I hope that helps
The following user(s) said Thank You: peterpj
