Question Kunena menu is not to see in categories
15 years 3 months ago - 15 years 3 months ago #104637 by Saphir
I didn't write it but I have the dot before.
Thanks for telling me hoe I have to make the settings that ist should work :)
I'm using a third party template and with all SEO settings in off my problem is gone. I still don't understand how this is connected but taht's OK. I thought I was reading that Kunena will work with searchengine friendly URLs.
Is there a way to get friendly URLs with Kunena?
I also like to say that I really like Kunena and I didn't want to say anything bad ore unlovely about it.
Thanks for your fast and good help!
Last edit: 15 years 3 months ago by Saphir.
15 years 3 months ago #104670 by sozzled
Saphir wrote: Thanks for telling me how I have to make the settings that should work :)
So, you see, you've proven that there is a connection between using SEO and the menu not working. This is what I've been trying to tell you and it has taken over 2 days just to prove the point. So, when I tell you the next thing to do you can either scratch your head and question my reasoning or you can try the idea for yourself and see whether it works or not.
You need to properly implement SEO. Kunena works well with and without Joomla's native SEO (including third-party SEO products) but, if you're using SEO, you must configure it properly. This is all explained in Search Engine Optimisation (SEO) in the Wiki
For Apache servers this means you need to do three things in J! 1.5.23:
(1) Global Configuration » Site » SEO Settings » Search Engine Friendly URLs = Yes
(2) Global Configuration » Site » SEO Settings » Use Apache mod_rewrite = Yes
(3) Rename the file htaccess.txt in your Joomla root directory to .htaccess
For J! 1.5.23, the standard .htaccess file is exactly 3596 bytes.
The other part of the problem relates to how you've setup your Kunena menu.
You have a menu item in your topmenu menu called "Forum". This needs to be menu item type = Alias. This is all explained in Customised menus in the Wiki.
