Question Kunena Menu Problem
14 years 9 months ago #104044 by ajschwin
Kunena Menu Problem was created by ajschwin
Greetings,
I am having a worrisome problem, whenever my users navigate to almost anything besides the entry page, the menu gets removed. One strange problem(possible solution?) Ive notice that it is appending a ?defaultmenu=205 to the end of the URL when I click on a catagory or directly view a thread. Is there any simple fix for this?
Thanks in Advance
Andrew Schwinn
arrowheads.com/forum/index
Arrowheads.com
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 100M | Max file upload: 4M
Joomla default template details : tmpl_arrowhead | author: Khalid Meraj | version: 1.0.2 | creationdate: 04/19/10
Third-party components: AlphaUserPoints 1.5.13 | Jomsocial 2.2.4 | UddeIm
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | My Kunena Forum Posts 1.6.4 | Kunena Groups 1.6.4
Modules: Kunena Latest 1.6.4
14 years 9 months ago #104092 by xillibit
Replied by xillibit on topic Re: Kunena Menu Problem
You can try to recreate the Kunena menu by using the function (create menu) in Kunena configuration panel.
14 years 9 months ago #104102 by sozzled
Replied by sozzled on topic Re: Kunena Menu Problem
I have a suspicion that the problem may lie with sh404SEF; however, I also suggest that your go to the FAQs tab on the menu near the top of this page. Please read Kunena menu issues
Time to create page: 0.259 seconds
