Question Hiding passages of text in posts
15 years 4 months ago #102221 by rtraub
Hi!
Please can anyone help answer two questions I have about hiding passages of text from posts?
1. Hiding a passage of text causes Kunena to generate default messages indicating that the passage has been hidden. Guests (i.e. anyone barred from seeing the passage) receive this message:"Something is hidden for guests. Please log in or register to see it." My problem: I'd like to change this message's wording and (if possible) have it display in bold type.
Contrastingly,Logged-in registered viewers (i.e. anyone not barred) receive this message:Hidden text:
Part of the message is hidden for the guests. Please log in or register to see it.
to hide part of a message from Guestsand the passage of text is displayed in italics. My problem: How to prevent both of these behaviours, such that the viewer simply reads the passage without either indication that it is hidden from guests.
Since Kunena's back-end configuration pages offer no option for controlling these behaviours, I'm presuming they are defined and alterable at script level. However, skimming through all of com-kunena's .php and .js files, I wasn't able to track down any obviously apparent lines of code for doing so. Can anyone enlighten me?
2. My other question is: is it possible to alter the minimum access-level at which users are able to see hidden passages of text? I've configured my Joomla! site's ACLs such that there's a level for unregistered Guests, one for registered and unregistered guests, and one for community members only; I'd like to be able to configure Kunena such that only community members can see hidden passages. Currently my Kunena is configured to comply with my Joomla! ACL scheme, allowing users to access Kunena without recourse to its own separate log-in. Admittedly, one obvious solution would be just to disable Kunena's dependency on the Joomla! scheme, to reinstate its own default scheme and its log-in/registration provisions, and to instruct users to log into Kunena with their normal password which K. would evaluate as either "registered" or "guest". However, I'd prefer to avoid this obviously more cumbersome and prosaic method and preserve the seamlessness of my current setup. So, please - can anyone advise me on this?
All thanks for your attention!
Time to create page: 0.099 seconds
