Question Forum does not appear
15 years 6 months ago - 15 years 6 months ago #93270 by RinaldoT
Hello everyone,
K1.6 I installed on Joomla 1.6.3, in addition to the error message during installation on the existence of a menu item that already exists that I proceeded to take off, I can't in any way to view the forum.
I state that I applied all that is described in the installation guide.
The configuration is as follows:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 3M
Joomla default template details : appio_10 | author: | version: 1.0 | creationdate: 2011-04-22
Can anyone help me ?
Last edit: 15 years 6 months ago by RinaldoT.
15 years 6 months ago #93276 by xillibit
Replied by xillibit on topic Re: Forum does not appear
Where do you have issues : frontend or backend ? What's happen exactly ?
15 years 6 months ago #93277 by RinaldoT
Replied by RinaldoT on topic Re: Forum does not appear
Frontend: Nothing appears, a blank page
15 years 6 months ago #93278 by xillibit
15 years 6 months ago - 15 years 6 months ago #93343 by RinaldoT
Ok I ran the dubug the result is as follows:
[IMG
The problem is given by another module, in fact if I disable it everything works!
Thanks for the tips
15 years 6 months ago #93371 by xillibit
This isn't an issue which is caused by Kunena but by your module lofarticlescroller, you need to check if he is compatible with Joomla! 1.6
Time to create page: 0.151 seconds
