Question Not ready for Joomla 1.6?
15 years 3 months ago #84779 by Matias
Try using lower case prefix for Joomla tables.. I reported a bug.
15 years 3 months ago #84835 by billh210
No they are two separate databases on two different computers and I did use lower case dht_.
I did try to delete the table and reinstall but just ran into the same problem.
15 years 3 months ago #84836 by billh210
Thought this might help
PHP Built On: Windows NT DHT-WEB1 5.2 build 3790 (Windows Server 2003 R2 Standard Edition Service Pack 2) i586
Database Version: 5.5.8-log
Database Collation: utf8_general_ci
PHP Version: 5.3.5
Web Server: Apache/2.2.17 (Win32) PHP/5.3.5
WebServer to PHP Interface: apache2handler
Joomla! Version: Joomla! 1.6.0 Stable [ Onward ] 10-Jan-2011 23:00 GMT
Safe Mode: Off
Open basedir: None
Display Errors: Off
Short Open Tags: Off
File Uploads: On
Magic Quotes: Off
Register Globals: Off
Output Buffering: Off
Session Save Path: c:/wamp/tmp
Session Auto Start: 0
XML Enabled: Yes
Zlib Enabled: Yes
Disabled Functions: None
Mbstring Enabled: Yes
Iconv Available: Yes
15 years 3 months ago #84855 by billh210
Ok found it my SQL database was DHT-WEB, it didn't like the - in the middle, had to rename it to DHTWEB. Now it works fine.
Thanks for the help
15 years 3 months ago #84955 by singletrack
That is good news.
General rule of anything that uses a DB - never use symbols that are utilized by the db syntax in any piece of the environment, and in your case, the naming convention.
Time to create page: 0.286 seconds
