Question Problem with Userlist and More statistics
15 years 10 months ago #80123 by c3da6df5dd8e8e868a652d04
I have an problem with the "Userlist and More statistics links" on the right-below position of the forum. When I click on those links the program start and is searching a long time but nothing happens. All the other things on the forum works correct.
I am using Kunena 1.6.2 and Joomla verion 1.5.22 stable. Mootools upgrade is enabled.
I hope that you can help me and hopefully know what the problem could be.
I thank you in advance.
Regards,
Gert
htaccess: Exists | PHP environment: Max execution time: 50 seconds | Max execution memory: 32M | Max file upload: 12M
Joomla default template details : ict_nepolis | author: atict.com | version: 1.5 | creationdate: 2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
15 years 10 months ago #80155 by sozzled
I can't see your Kunena forum on your website. Can you post the URL that shows this problem, please?
15 years 10 months ago #80224 by c3da6df5dd8e8e868a652d04
After all there are still problems with my template "ict-nepolis" of Atict.com and Kunena forum.
See for template : www.atict.com/index.php?option=com_conte...iew&id=212&Itemid=54
Some of the problems are solved. Do you have experience with Atict.com templates ?
I think that the problem lies in the template. I disabled mootools(they use mootools v1.1) from that template but the described problem remain exist. It is a pity but I had to switch and find an other template. I reinstall everything and with template "ja_purity" there are no problems.
Joomla is installed in www.musical-kaartjes.com/jos but now with template "ja_purity".
Regards,
Gert
15 years 10 months ago #80244 by sozzled
Thank you for the report about "ict-nepolis" template (from Atict.com ) and your recommendation not to use this template because it requires Mootools 1.1.
I'm pleased to hear that your site is now working well.
