Question Insert Videos, de-GE language, template Problems after upgrade RC2 to RC3
15 years 11 months ago #62752 by xillibit
larry007 wrote: Hi,
look post #3
Joomla Version 1.5.20
Uddeim Version 2.1
1°) There is an issue somewhere in the parser with video.
Do you now where or in what file must I show?
try it out here in kunena, it doesen't work too
The file is components\com_kunena\lib\kunena.parser.php
larry007 wrote:
and what about this?
the code button doesen't work when you klick. There is no Code display
{code}{/code} ({} only for demontration) in message Box seen.
I don't understand the issue
defined( '_JEXEC' ) or die(); jimport('joomla.utilities.string'); // Joomla absolute path define('KUNENA_JLIVEURL', JURI::root()); require_once (KPATH_SITE . '/lib/kunena.defines.php'); kimport('error');
15 years 11 months ago #62755 by 810
Hi, i already fixed this, just wait for the new release soon.
15 years 11 months ago #62756 by larry007
about the code button - I looked now better on the barcode box. When I klick to the code icon it open a dropdown field, then select the code and insert, ok to this.
Sorry it was my mistake, I have to look better...
But in RC2 this future wasn't so!!!
15 years 11 months ago #62779 by larry007
810 wrote: 1°) There is an issue somewhere in the parser with video
I used now the file from RC2 -> kunena.parser.php and it works fine
15 years 11 months ago #63449 by marco168
I am also looking for the solution for Q3. Any suggestion/guideline is appreciated=]
15 years 11 months ago #63457 by larry007
look to this answer of the producer, we must wait for RC3 changes in this template
pizcar.com.ar/joomla/kunena/55-argentrc-...na-template#comments
Time to create page: 0.254 seconds
