Question Registration doesn't seem to work
16 years 2 months ago #62220 by fluiddruid23
I'm having a problem on www.getransportation.com/join-the-conversation.html , which is using Kunena 1.6.0-RC2.
Firstly, the links below the login boxes are showing as:
www.getransportation.com/component/user/reset.html
www.getransportation.com/component/user/remind.html
www.getransportation.com/component/user/register.html
and I'd really like these to be:
www.getransportation.com/join-the-conversation/reset.html
www.getransportation.com/join-the-conversation/remind.html
www.getransportation.com/join-the-conversation/register.html
The second (and major) problem is with registration itself. When I click on 'Create an account', I get taken to www.getransportation.com/component/user/register.html . I fill in appropriate information and submit, but the page just seems to refresh and blank the fields. The registration doesn't seem to work.
Help? :unsure:
Thanks,
Matt Atherton
16 years 2 months ago #62306 by Matias
First issue needs a small tweak in administrator/components/com_kunena/libraries/integration/joomla15/login.php (I think I got it right). The links are defined in there.
Registration has nothing to do with Kunena. Your registration seems to have some extra in it (AJAX checks?), maybe the plugin doing the validation is broken? BTW: what are you using in there? It looks cool.
16 years 2 months ago #62308 by fluiddruid23
Hi!
Thanks for the reply. :)
I'll check out your tweak for the first issue.
As for the second issue, I knew it was Joomla core stuff, but didn't know if Kunena was affecting it. It turns out that registration is working, just doesn't take the user anywhere when registering.
I've now put in a new component, which allows for re-directs to success pages etc.
Here's what I am using: extensions.joomla.org/extensions/access-.../authentication/7361
Thanks,
Matt
