Question Template Issue with Kunena 1.6 RC2 and IE8
16 years 4 weeks ago #59970 by tramber91
Dear all
All is in title
here it is what I have
Only with Inernet Explore 8, OK with IE7 and Firefox
sometimes it is OK when I did a refresh but 1s later same issue (menus emoticones)
tamplate: Zephyr Roktheme
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Enabled (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Enabled (Version : 2)
thanks
16 years 4 weeks ago - 16 years 4 weeks ago #60121 by kat06
hi there,
this issue seems to be caused by the smartload feature which is part of the rockettheme gantry framework.
you can try to exclude kunena from smartload.
in your joomla admin please go to > extensions > template manager > zephyr > features > smartload...
and add the following to the field "component excludes": com_kunena
if you have other excludes there already, make sure to seperate them by comma, such as:
com_community,com_contact,com_k2,com_tienda,com_weblinks,com_kunena
please let us know if that helps,
kat :)
rockettheme
Last edit: 16 years 4 weeks ago by kat06.
16 years 3 weeks ago #60179 by snilloconator
Or you could just disable smartload for that specific menu item. Well that's what I did and it seem to work.:ohmy:
16 years 3 weeks ago #60274 by tramber91
Dear all
thanks for your answer
It is not the clue for the menu
concerning menu, I just removed the famous
-moz-border-radius-topright:5px;-moz-border-radius-topleft:5px;
from kunena.forum-min.css default template and it is OK now
take care
16 years 3 weeks ago #60415 by kat06
hi again,
not sure what you mean about the menu?
did the solution i mentioned fix the issue with the smilie images for you?
kat :)
rockettheme
16 years 3 weeks ago - 16 years 3 weeks ago #60437 by fxstein
kat06 wrote: hi there,
kat :)
rockettheme
Kat,
Is there something we can do on our end so users don't have to enter us as an exception for the auto load?
Honestly we know way too little about Gantry and it sure would be nice to stick heads together with one of your designers/architects/developers to see how we can integrate better and leverage each others capabilities.
I am certain that most issues that are seen, are caused by minor things, that - once known - could be architected for.
If anybody from your team is planning to come to Joomla Day USA West, I would love to host a get-together.
As always - thanks for your continuos help!
Last edit: 16 years 3 weeks ago by fxstein.
Time to create page: 0.312 seconds
