Question forum header gone..
16 years 3 months ago #56679 by madLyfe
forum header gone.. was created by madLyfe
just installed a fresh joomla install along with kunena rc and everything was fine but the menu item was setting kunena to recent topics and i wanted it to show the board index so i changed it and this is what i get. also now no matter what i change it to it stays the same:
word up!
16 years 3 months ago - 16 years 3 months ago #56680 by sozzled
If you mean the Kunena top (navigation) menu tabs are missing, then please confirm that I have correctly understood your question.
Please see Missing Top Tabs [solved] for advice that will help you. B)
Last edit: 16 years 3 months ago by sozzled.
16 years 3 months ago #56681 by madLyfe
sozzled wrote: If you mean the Kunena top (navigation) menu tabs are missing, then please confirm that I have correctly understood your question.
ok cool that worked, but shouldnt that be the default way of working? instead of having to go in and change it?
word up!
16 years 3 months ago #56682 by sozzled
It normally is the way things work from scratch. Sometimes these things don't work and that's a bit of a puzzlement. We're trying to settle these things down so that users don't have to do a lot of extra post-installation patching-up. Unfortunately, just at the moment, it's one of those things.
I'm glad it all worked out for you. :)
16 years 3 months ago #56683 by madLyfe
sozzled wrote: It normally is the way things work from scratch. Sometimes these things don't work and that's a bit of a puzzlement. We're trying to settle these things down so that users don't have to do a lot of extra post-installation patching-up. Unfortunately, just at the moment, it's one of those things.
oh ok, i didnt know if thats the way it was supposed to be by default(final version).. thanks for the help!
word up!
16 years 2 months ago #59413 by madLyfe
just installed RC2 and i guess this buggie is still on the fix list, but i have another observation and it might just be a setting im missing.. i want the index to be the default for my forum.. so on a fresh install the top breadcrumb for kunena is "Kunena", but when that is clicked it takes you to "recent topics" instead of the index for the forum..
thanks,
madLyfe
word up!
