- Thank you received: 1
Question Kunena + enable MooTools = problem for every second template?
16 years 3 months ago - 16 years 3 months ago #55962
by crazyawm
hi
my engkish not good, but i want my about my problem
in my test domain i have:
Joomla 1.5.20
Kunena 1.6
Different temlates from YooTheme, Roket, JoomArt, XTC, and other
its temlates have many modules with JavaScript (slider, carousel, accordeon and other)
when i install Kunena 1.6, i dont see smile. ok, its not problem. i go to www.kunena.com/forum/156-kunena-16-test-...opdown-missing#52040 , download modifed mootools upgrade and setup + enabled in my site (thanks @quila
but whene i enabled its plugin my modules with JavaScript not work, if i disabled its plugin - not work smiles and bbcode in Kunena
i see different forum in russian and english language 3-4 day and cannot see topic about this problem... But very lot discuss about this problem (enable mootools + modules with javascript) in templates creator forums and blogs, and too not answer...
what to do? you can help me?
may be can make mootools plugin just for Kunena component?
UPD: forget... last templates whene i see its problem - JA Ores
Joomla 1.5.20
Kunena 1.6
Last edit: 16 years 3 months ago by crazyawm.
The topic has been locked.
16 years 3 months ago #55971
by darksoul
Replied by darksoul on topic Re: Kunena + enable MooTools = problem for every second template?
I use yootheme Phoenix template...
I solved disabling "Use mootools 1.1" from settings.
16 years 3 months ago - 16 years 3 months ago #55972
by crazyawm
Replied by crazyawm on topic Re: Kunena + enable MooTools = problem for every second template?
when you disable MooTools - at you work smiles and bbcode? at me not... its my problem
work smiles and bbcode - dont work javascript, work java script - dont work smiles and bbcode
now i install kunena in website where i have templates Yootheme Enterprise - same problem too.....
i want make normal website with normal kunena forum 1.6 - why its dont possible?.. dont understand...
weit when fix its bug
The following user(s) said Thank You: gabber3000
16 years 3 months ago #55975
by fxstein
Replied by fxstein on topic Re: Kunena + enable MooTools = problem for every second template?
This is not a bug.
Kunena 1.6 requires Mootools 1.2+ which comes with Joomla 1.5.19+ and 1.6.0+
Any template that still uses Mootools 1.1.x needs to get updated to Mootools 1.2.x
Many templates already give you that option - like the example given before.
Going forward ALL Joomla templates will be based on Mootools 1.2 or a completely different js library like jquery. Both will work just fine. Any oudated templates that still use the 3+ year old Mootools 1.1 libraries will have an issue going forward.
Hope this helps!
This is not a bug.
Hope this helps!
16 years 3 months ago - 16 years 3 months ago #55978
by crazyawm
you mean, i need take new templates version at templates creators? or what? i a little dont understand...
if you say about MooTools upgrade plugin, i write in my first post
now i have
Joomla 1.5.20
Kunena 1.6
Different temlates from YooTheme, Roket, JoomArt, XTC, and other + MooTools Upgrade Plugin (last version @quila)
when i install Kunena 1.6, i dont see smile. ok, its not problem. i go to www.kunena.com/forum/156-kunena-16-test-...pdown-missing#52040 , download modifed mootools upgrade and setup + enabled
now i have
Joomla 1.5.20
Kunena 1.6
16 years 3 months ago - 16 years 3 months ago #55981
Replied by sozzled on topic Re: Kunena + enable MooTools = problem for every second template?
Thanks, Oliver, this explains a lot to me, too.
We've often found, in handling requests for support in this forum, that many problems have in the past been wholly attributed to the templates that users have chosen for their websites. As I have written elsewhere, if the look and feel - the theme - of your website is more important to you than having a fully-featured forum component, like Kunena, then you will need to look at other options for running your forum. If, for you, having a fully-featured Kunena forum is important, then you may have to make other choices about the site template that you want to to use.
As Joomla develops everything changes. Templates and Javascript libraries are two prime examples. It's much like when J! 1.0 stopped and J! 1.5 took over. Many of the older J! 1.0 site templates would not work with J! 1.5 without enabling "legacy" mode. This was to give J! 1.0 template designers the opportunity to update their old templates for the newer version of Joomla. "Legacy" mode was to give people a bit of breathing space.
Some template designers took advantage of this and some didn't. Those that didn't update their templates for Joomla 1.5 soon gained a bad reputation.
Therefore, getting back to the topic, the question is entirely a matter in choosing a reputable template designer for Joomla. Remember: "All that glisters is not gold". You may have chosen a template that looks great but, when you get into the nuts and bolts, it's actually more trouble than it's worth.
crazyawm: you need to write to your template supplier and ask them what plans they have to make their template Mootools 1.2-compliant.
Last edit: 16 years 3 months ago by sozzled.
