Sticky All issues with IE7 FIXED - need testers
16 years 3 months ago - 16 years 3 months ago #54660 by @quila
as you know we want that our users can run Kunena with all modern browsers. One of them is IE7 :)?????
I have fixed 99% of issues with this browser. I cant (want) to install IE7 on my PC, I cant find it for download, I cant upgrade IE6 to IE7(only to IE8).
Well, we have a problem and need someone to test all fixes.
Hope sameone already have this browser installed and can run Kunena to see if all bugs are fixed.
How?
Go HERE and open that site with your IE7 and if you find some bug report here (with screenshout and IE version).
Known issues:
  • QUICK REPLY dont work - still investigate
You can Login with
Username: demo
Password: demouser
Thank you in advance for all your report.
Last edit: 16 years 3 months ago by @quila.
The following user(s) said Thank You: roland76
16 years 3 months ago #54661 by MAW_Trok
Since I had many problems before your help... I can use IE7 for help you :-D I will post some impression soon! :-D
16 years 3 months ago - 16 years 3 months ago #54663 by MAW_Trok
Good work... there is only a little problem with the buttons... the icons are not totally alligned with the links.
Last edit: 16 years 3 months ago by MAW_Trok.
16 years 3 months ago - 16 years 3 months ago #54664 by @quila
Hi, thanks for report, you are using IE8 with "Compatibility mode" enabled or IE7?
16 years 3 months ago #54666 by MAW_Trok
16 years 3 months ago - 16 years 3 months ago #54668 by MAW_Trok
Can you write the changes that you made? I want upgrade my site.... as I told.. I already have k1.6 on my site and I would fix this problem :-D
for the quick reply.. its really strange.. I am also investigation. :S I really don't know what could be the problem.
