Question sef links or urls with kunena 1.6
16 years 2 months ago #54371 by pdfinformation
Joomla - 1.5.20
Kunena - 1.6
SEO component - SH404SEF
I have installed kunena 1.6 in a test site. Checking it for SEF urls
In the earlier version of kunena i.e 1.5 sef url's were created for the posts. For example www.abx.com/topic/why-using-kunena
Now in 1.6 sef urls are not created. For example www.abx.com/topic/t-297
Is their any settings am missing in kunena or SH404SEF ?
16 years 2 months ago #54376 by Hurr1c4n3
Why don't you lose SH404SEF and just activate SEO in Joomla and Kunena?
16 years 2 months ago #54402 by pdfinformation
Many of the live sites are using sh404sef. So its good to test the kunena 1.6 with sh404sef installed.
Is it the issue with sh404sef ? I mean not compatible with kunena 1.6 ?
16 years 2 months ago #54409 by sozzled
Thank you for reporting your K 1.6 issues in the test reports category. While we cannot give any guarantees that there is a solution for the sh404SEF problems (and, in the past week, there have been a few instances where people have reported difficulties with that product), we will investigate your report further and and subject K 1.6 to further testing with sh404SEF.
I have not seen any official statement about the level of compatibility between K 1.6 and sh404SEF (I don't know what collaboration between the development teams of Kunena and sh404SEF) but we will try to get an answer back to you as soon as possible. I don't know what testing has been done with sh404SEF - I haven't seen any reports of issues involving this product and K 1.6. Your report may well be the first!
The Kunena 1.6 test reports category is not a support category:
This category is only for reporting defects or problems with Kunena 1.6 alpha/beta test versions. This is NOT a support forum - there is no support for alpha/beta test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
We will try to help you if we can.
The best advice that I give at this time is for you to ask the developers of sh404SEF what work they are doing to resolve the problems that you seem to be encountering. I will try to get an answer about how compatible K 1.6 is supposed to be for sh404SEF.
The following user(s) said Thank You: pdfinformation
16 years 2 months ago #54553 by pdfinformation
Thank you sozzled for your review and answer.
I will raise this compatibility issue with developers of sh404sef also.
Another thing is its computability with joomap or xmap :)
For any product to succeed compatibility among different product is must! Hope new Kunena will have the compatibility like the current one!
16 years 2 months ago #54559 by svanschu
Hi pdfinformation,
I don't know joomap and xmap as sitemap components but I think they work like SEF Service Map that you have to install an plugin into joomap or xmap. If it is so someone have to wrie one for 1.6
I also look atm around for a better Sitemap Component than SEF Service Map and don't know atm for which I will use and configure for kunena
