Kunena 7.0.8 Released
Sticky K 1.6 BETA 1 B3068: Object of class CKunenaConfig could not be converted to string
16 years 1 month ago - 16 years 1 month ago #53613 by MAW_Trok
I found this error when i try to go in the hompage.. I have kunena last version 1.6 beta1 and joomla 1.5.20!
Catchable fatal error: Object of class CKunenaConfig could not be converted to string in /web/htdocs/www.my_site.com/home/administrator/components/com_kunena/libraries/user.php on line 68
and is not possible to unistall!
Last edit: 16 years 1 month ago by sozzled. Reason: Changed subject to improve search relevance
16 years 1 month ago #53616 by etusha
Replied by etusha on topic Re: kunena bug
Please can u post your "Report Configuration Settings"
16 years 1 month ago #53623 by MAW_Trok
Replied by MAW_Trok on topic Re: kunena bug
ops, I can't now because i tried to upgrade one of my site, but I unistalled quickly because there was this problem. I could try to istall again, but in the night when there are no users connected. :-D and post the report on this forum.
16 years 1 month ago #53633 by Mortti
Replied by Mortti on topic Re: kunena bug
MAW_Trok wrote: Catchable fatal error: Object of class CKunenaConfig could not be converted to string in /web/htdocs/www.my_site.com/home/administrator/components/com_kunena/libraries/user.php on line 68
Please clean your Joomla! cache, then it should work as normal.
MAW_Trok wrote: and is not possible to unistall!
This is well know bug (little bug), search in the forum and you will find answer.
16 years 1 month ago #53642 by etusha
for uninstall edit "administrator/components/com_kunena/install/model.php"
remove line 1011 and 1012
this line
if (KunenaError::checkDatabaseError ()) return;
this is known bug and is fixed
16 years 1 month ago - 16 years 1 month ago #53646 by MAW_Trok
This is the report
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Kunena version detailled: Installed version: 1.6.0-BETA1 | Build: 3068 | Version name: | Kunena detailled configuration:
Last edit: 16 years 1 month ago by MAW_Trok.
Time to create page: 0.405 seconds
