Question Modules 'Position' dropdown - MISSING
16 years 4 months ago - 16 years 4 months ago #52037 by Unb4nned
I've installed Kunena 1.6 alpha 2 on several test sites, all running Joomla! 1.5.18. All works properly, but after the installation this happens:
When trying to change ANY module position it just wont let me, as the dropdown that's supposed to be there disappears.
Im using the latest Kunena build.
Server info, just in case:
MySQL Version 5.0.45
PHP 5.2.2
Last edit: 16 years 4 months ago by Unb4nned.
16 years 4 months ago #52039 by Cerberus
This is a joomla issue and not kunena. please ask the devs at joomla about this as kunena has nothing to do with the module manager..
16 years 4 months ago - 16 years 3 months ago #52040 by @quila
Hi, this is known bug in Mootools 1.2 you have installed with K1.6b2. To solve the problem use this one attached. Uninstall Plugin Mootools1.2 then install this one and dont forget to activate ;)
Last edit: 16 years 3 months ago by fxstein. Reason: Removed attachment
The following user(s) said Thank You: linux, authentic, Unb4nned, eigenheimer
16 years 4 months ago #52042 by Unb4nned
@quila wrote: Hi, this is known bug in Mootools 1.2 you have installed with K1.6b2. To solve the problem use this one attached. Uninstall Plugin Mootools1.2 then install this one and dont forget to activate ;)
Working like a charm now, thanks alot for your help :)
16 years 4 months ago #52051 by fxstein
FYI the Kunena 1.6 Beta version will ship with this updated plugin. We just got the fix from the Joomla team on Friday.
16 years 3 months ago #55968 by fxstein
Please DO NOT INSTALL this mootools plugin if you have Joomla 1.5.19 or later. Joomla ships with the latest version of this plugin already.
