Question Kunena 1.6 will conflict with other components because of his mootools upgrade plugin
15 years 9 months ago #51539 by jimie
15 years 9 months ago #51552 by Cerberus
mootool is a joomla plugin and will be included in j1.5.19 as standard BUT it does have some bugs that the joomla devs are currently working on.
15 years 9 months ago #51562 by fxstein
jimie wrote: Kunena 1.6 will conflict with other components because of his mootools upgrade plugin
And its default for Joomla 1.6
We have taken the step that many devs need to do as well - update many year old outdated code. If your template or app still runs on mootools 1.11, the developers need to spend a little time and upgrade it to 1.2
mootools 1.2 works find with jquery (as you can see here on this site - jomSocial is cuurrently still on jquery). Only old mootools 1.11 code will have to get upgraded.
We took the time to do that, other developers will have to do the same.
15 years 9 months ago #51608 by shumisha
hi
Nope, sorry. You are breaking very recent code, that only use tabs in the backend. Yes, just Joomla built in tabs. That may be the issues you are talking about that are being worked out by Joomla team, but ATM installing Kunena 1.6 probably breaks many extensions.
Second, we don't need to update our code to 1.2, but actually make it so that it works on both 1.1 and 1.2, which is is not as simple as it seems.
But again biggest issue is that basic Joomla API is broken by including this plugin.
So this is only an alpha version of Kunena and therefore just for testing purposes, but you should be aware. At least, the plugin should be disabled in the backend.
Rgds
15 years 9 months ago #51637 by fxstein
There is one more bug in the plugin that we are waiting for from the Joomla core dev team. Once that bug is fixed ti will work with 1.11 and 1.2 code. We have been working with the Joomla core dev team since beginning of the year to test and fix this plugin.
15 years 9 months ago - 15 years 9 months ago #51650 by severdia
In one week, Joomla will be shipping with Mootools 1.2 so developers will need to update their extensions (or Javascript code) or get left behind by their users. Kunena 1.6 is using a development version of the same plug-in that will be in Joomla 1.5.19. If it breaks the UI or API in some places now, that's the reason. But those issues will be resolved by July 15.
community.joomla.org/blogs/leadership/12...ard-with-joomla.html
In the interim, remember that both this plug-in and Kunena 1.6 are not final. We wanted to start using the plug-in early on so we could work out the Kunena-specific bugs.
Last edit: 15 years 9 months ago by fxstein. Reason: June -> July
