Question menu item #current is not working correctly
16 years 5 months ago #49696 by Dr. Wuah
Hey!
To my installation environment:
Local installation with xampp and my joomla! installation is configuered as suggested in an other topic.
My Problem is: I created a menu in joomla! and pointed a menu link to the forum and another directly to an user's profile.
Both links are connected with the right pages, which are shown correctly. But normaly an active menu item is assigned with the "current" id and therefore customizable through the css file. This doesn't happen.
I'm not sure if I am making a mistake, or whether this issue appears to be a probleme for everyone.
16 years 5 months ago #49720 by xillibit
I don't understand exactly, what you mean by : "But normaly an active menu item is assigned with the "current" id and therefore customizable through the css file. This doesn't happen"
16 years 5 months ago #49755 by Dr. Wuah
ok, I try to explain it more clearly ;)
For example: look at the menu bar on this site. You'll see the "Forum" menu link has an darker background color. This darker color for "active" menu links is assigned through css and the for example with the "current" id(, which you can see with tools like firebugs :
<li class="active item125" id="current">
<a href="/forum"><span>Forum</span></a>
</li>)
If I try to change the look of this active menu link nothing happens. All menu links, except for the kunena links, are working properly.
I hope the problem is clearer now...
16 years 5 months ago #49757 by @quila
Yes, you are right.
There is a bug in css file which is already fixed as you can see on demo site.
Fix will be present in the next release.
Thank you for report this.
Regards
16 years 5 months ago #50149 by Matias
Next version also have some improvements on menu items in general. :)
16 years 3 months ago #55729 by fsoares
Now I am testing Kunena v1.6.0-RC1_b3173_2010-08-09 and have same problem, or similar.
When select the Forum menu (link to kunena_menu > forum) this is highlighted but if select an category from the forum then the highlight is turned off, as if nothing of these menus is selected.
This is a minor bug that can be solved in future, but that can cause confusion to the "users".
Fernando Soares - Mantendo sua Tecnologia
Hospedagem Joomla e VirtueMart Hosting
twitter.com/fernando_soares
www.fernandosoares.com.br
