Question Rules/Help Pages
16 years 5 months ago #49169 by hjames
Rules/Help Pages was created by hjames
I have noticed in some instances (2 seperate installs) that K1.6 is not disabling the Rules and Help pages when these options are selected. I have not pinpoint the result of the issue.
I am sure K1.6 Dev Team will find it before I do.
Thanks,
James
Joomla 1.5.24
16 years 5 months ago #49174 by fxstein
Replied by fxstein on topic Re:Rules/Help Pages
I believe what you are seeing is due to the navigation now being a Joomla menu. If you go into the menu manager and look for the Kunena Menu, you can re-arrange the layout, order and which ones should be visible, just like with any other Joomla menu.
We still might have to cleanup some more of the legacy options.
16 years 5 months ago #49238 by hjames
Replied by hjames on topic Re:Rules/Help Pages
Understood!
Do you have a Doc for K1.6 that is in the works? I would like to look it over if possible and add to it or refine things if possible and time permits.
James
Joomla 1.5.24
16 years 5 months ago #49243 by Matias
Replied by Matias on topic Re:Rules/Help Pages
Almost nothing this far -- we have just been too busy on coding. It would be great help to get some new documentation (wiki) on how things work in K1.6!
16 years 5 months ago #49351 by xillibit
Replied by xillibit on topic Re: Rules/Help Pages
In kunena panel configuration, in the tab frontend set Enable Rules Page and Enable Help Page to no and will see like magic that these tabs disappear in frontend.
I have just re-tested, it's working like it should.
