Question redirect to Index of /forum
Your problem is actually more of a Joomla menu issue than anything else. It's fairly easily solved by removing all your existing menu items and using the Create Menu facility on the Kunena contol panel.
Your other problems, seem to stem from the way that you are trying to use SEF URLs. I suggest that you read Search Engine Optimisation (SEO) in the Wiki to get your Joomla site in shape.
BWes wrote:
Yes, that's what everyone says. Setting up SEO is not as simple as making sure that two radio buttons are selected in the Joomla Global Configuration. Setting up SEO in Joomla also requires another important other step, too: making sure that you have a working .htaccess file in the root folder of your site.I have the following SEO values
* Search Engine Friendly URLs: Yes
* Use Apache mod_rewrite: Yes
* Add suffix to URLs: No.
A lot of people tell us that they have a working .htaccess file in the root directory of their site. Quite often time they are mistaken. The standard .htaccess file for Joomla-built websites (it's shipped with Joomla as htaccess.txt) for J! 1.5.22 is exactly 2773 bytes. How large is your .htaccess file?
