Question Kunena main page does not load
15 years 8 months ago - 15 years 8 months ago #89115 by Victorius
I installed Kunena which worked perfectly, then disabled it, because I wanted to use it at a later time.
I changed my hosting provider, installed my site, and a couple of weeks later I decided it is time for Kunena go live. I enabled everything in the menu manager, however, when clicking on the Forum menu on my site, I receive this error and the maing page does not load:
Fatal error: Call to a member function getLink() on a non-object in /home/konzolce/public_html/administrator/components/com_kunena/libraries/user.php on line 374
I downloaded the user php file, and in line 374 I find this:
return $avatars->getLink ( $this, $class, $sizex, $sizey );
The thing is that I don't understand why it is not working, after disabling the forum I did not change, modify anything.
Does anyone have a hint?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details :
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Last edit: 15 years 8 months ago by Victorius.
15 years 8 months ago #89128 by xillibit
Do you have tried to upgrade to k1.6.3 to see if the problem persists ?
15 years 8 months ago - 15 years 8 months ago #89140 by sozzled
I cannot add anything more to what xillibit has written. There is no way that this community can fully support users who deliberately edit or conceal information from the standard K 1.6 configuration report. Sorry.
I can only suggest that you read K 1.6 Technical Requirements in the hope that this may provide you with some answers.
