Question login issue
15 years 9 months ago #87151 by beyondthenet
login issue was created by beyondthenet
After the activation link has been clicked, a new user can login using the top Joomla login but not the Forum login. It gives the error "Your registration process is not yet complete! ...."
This seems to be the same issue on all browsers.
lineboring.org/
user: test2
pass: 86325
thank you!
15 years 9 months ago #87188 by GoremanX
Replied by GoremanX on topic Re: login issue
Your forum configuration report (from the Kunena backend) would be most helpful for diagnosing this. You make no mention of Joomla version, Kunena version, or anything else that might be relevant. Also, this is a very weird category to be asking your question.
www.friendlyphotozone.com
15 years 8 months ago #87510 by beyondthenet
Replied by beyondthenet on topic Re: login issue
Sorry, I'm new to Kunena forum and did know about the Config Settings. Here it is. Using Kunena 1.6.0.
Thank you
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 20M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
15 years 8 months ago #87526 by sozzled
Replied by sozzled on topic Re: login issue
Please upgrade to K 1.6.3.
15 years 8 months ago - 15 years 8 months ago #87605 by beyondthenet
I just updated to 1.6.3.
On this page I can login using the top Joomla login but not the Kunena login:
lineboring.org/forum/recent
user: test2
pass: 86325
I get this error message. No email comes, however. Thank you.
The profile page is not available for guests
Your registration process is not yet complete! Please check again your email for further instructions that have just been resent. If you don't find the email, check your spam-box. Make sure that your email account options are not set to immediately delete spam. If that was the case, just try logging in again to receive a new instructions email
Last edit: 15 years 8 months ago by beyondthenet.
15 years 8 months ago #87687 by GoremanX
in the Kunena configuration, on the Integration tab, try changing the login integration to "Joomla".
Time to create page: 0.212 seconds
